looking at a 2007 XC90 3.2
So I have an opportunity to purchase a great looking unit, almost perfect condition owner has always had serviced at the dealer last year they put new yr diff as it got noisy when it was taken in they said nothing wrong. her dad took it in said just replace it.
Anyway, as I said it is a 07 got all the bells and some more has 140,000 km, not a mark drives great. One thing needed for cert according to deal is a CEM cable to the Engine compartment for 1000 to 1500 bucks it had the dreaded blocked tubes issue. Rather than bother to fix she let it go and rained and ran on the CEM other than that no issue. also has a set of winter tires mounted to go with it. after looking around I thought I would take as-is for the 3000 they asking and try and clean the connectors. As the tubes and water leaks were fixed at the time of safety check if nothing else I can source a harness if needed. safety can be got later when ready over the past year had 2 new bearings in the front of the front brake and back. Winter Michelin put on in fall mounted on new Volvo rims
it shows very well no leaks sounds great shifts perfect no binding on tight turns. all fluids were changed at dealer last visit.
your thoughts...
your thoughts...
