loose passenger window
I have an '04 xc-90. I went to put down the passenger window yeserday and the window came "loose" and seems disconnected from the mechanism that puts it up and down. I was going to take off the door panel to take a look. Anyone have any tips on the panel removal or the re-attachment of the window? Thanks!
pry out silver door handle
there are two? screws under that handle, and one at the bottom of the panel
remove all of them screws
pry out the panel from the metal -it is held by clips to the door, carefully remove panel, there is a lock pin in the panel top
I removed th epanel tonight and did the repair. You were right about the 2 screws under the handle "cover". The panel came off easier than any I hve worked with before. Found and repaired my problem - the tracks for the motor guides fell off of the bottom of the window. I used some good Urethane sealant, reassembled, and will leave it up for a few days to insure it dries fully.
850GLTWAGON
Nov 21, 2008 04:14 PM
