Low beam failure
Old Aug 20, 2017 | 07:43 PM
Hockeydad2366's Avatar
Exclamation Low beam failure
The drivers side HID bulb failed on my 08 xc90. I replaced both bulbs and now the drivers side bulb turns on but then goes out after a few minutes. I did some additional research and based on this and I replaced the ballast but I still have the same problem with the headlight going off after a few minutes. Looking for any help as to what to do next. What's weird is that the daytime running light is also out and when I inspected the bulb it appears to be fine.
Thanks!
Old Sep 2, 2017 | 07:14 AM
Moses Osiru's Avatar
Which year is your car? Make sure you check the connection between the bulb and the wire (the metal connectors). Sometimes they get corroded, or the connection is loose and you get the same message.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
Turbogirl7
Feb 6, 2024 06:37 AM
jasonthaynes
Dec 2, 2012 05:32 PM
llcoollam
Apr 24, 2006 06:54 PM
V50T5
Mar 19, 2006 04:35 PM
