Sponsored by:
Sponsored by:
Low beam failure
Old 08-20-2017, 07:43 PM
Hockeydad2366's Avatar
Exclamation Low beam failure
The drivers side HID bulb failed on my 08 xc90. I replaced both bulbs and now the drivers side bulb turns on but then goes out after a few minutes. I did some additional research and based on this and I replaced the ballast but I still have the same problem with the headlight going off after a few minutes. Looking for any help as to what to do next. What's weird is that the daytime running light is also out and when I inspected the bulb it appears to be fine.
Thanks!
Old 09-02-2017, 07:14 AM
Moses Osiru's Avatar
Which year is your car? Make sure you check the connection between the bulb and the wire (the metal connectors). Sometimes they get corroded, or the connection is loose and you get the same message.
Turbogirl7
02-06-2024 06:37 AM
Volvo_Neps
1998-2000 model year V70
10-07-2013 10:28 PM
jasonthaynes
12-02-2012 05:32 PM
llcoollam
04-24-2006 06:54 PM
V50T5
03-19-2006 04:35 PM
Quick Reply: Low beam failure
