Messages from car, codes, dead car
Old Dec 19, 2021 | 08:01 AM
Ambern179's Avatar
Default Messages from car, codes, dead car
I'm getting messages from my 2007 volvo xc90. One message is anti-slip service required. One is sporadic and saying something like bulb position failure, one is charging system service required (something like that) I have 2 codes come up on my code reader p2419 and p2401 (I think) I was sitting in my car yesterday waiting for my husband and a random.message popped up saying brake system failure stop safely then my car died. (Car wasn't moving) any ideas? Im leaning towards the ECM but I'm praying someone has a different resolution. Lol. My code reader checks my battery and alternator those are fine
Old Dec 19, 2021 | 09:36 AM
Originally Posted by Ambern179
2007 volvo xc90.
Anti-slip and brake system failure - mean a self diagnostic trouble code/s is stored in the abs control unit. - A compatible scan tool is needed to read codes from the ABS system - Can your scanner talk to all the control units? Or do you just have a basic obd only scanner that usually only talks to the ECU and Transmission control unit - for emission related codes? A common problem is bad connections in the ABS control unit. Many companies " rebuild" those in varying degrees of quality. Xemodex is a good quality source. If a new ABS control unit is installed a software download using a VIDA subscription is required to make the new part work. A xemodex unit will come pre-programmed if they don't fix yours. (you provide your VIN when purchasing)
Bulb position failure - one or more of the rear parking light bulbs is out or erratic. "Position lights" are your parking lights. (middle position on the light switch) One in each headlamp assembly, and 2 in each taillamp assembly. (or two at each rear corner, some cars use the light in the bumper as a rear parking light) The bulb out system only cares about the rear parking lights - if the fronts are out you will not get that message.
Charging system service required - the voltage is either too high or too low when that message occurs. You may have an alternator overcharging or undercharging at times.
P2401, P2419 - Those are Evaporative emission codes. One is for the leak detection pump. An electric pump pressurizes the air in the gas tank to determine if there is an evaporative leak - (like leaving your gas cap loose or off, or a broken vent hose) With the original software the system determined if there was a leak by the amount of current used by the pump. As the pumps got older - they used more current and the system would report that code erroneously. A new pump usually fixes that. You can update the software and the ECU will use different parameters to set that code - but many leak detection pumps have been replaced because they are bad. New software is done using a VIDA subscription.
There's nothing wrong with your Engine control unit. At least it has nothing to do with the things you have listed.
Don't replace anything using the guess and check method - it gets very expensive and frustrating that way.
mspencerV70
2001-2013 model year V70
13
Nov 12, 2020 07:07 PM
Saxongwara
Feb 27, 2020 08:02 AM
Paul Wood
Jul 15, 2019 03:50 PM
bluemagicbus
Dec 8, 2008 09:54 AM
BILL_MCCASSEY
Oct 18, 2008 06:37 AM
