New owner with transmission q’s
Old Oct 24, 2019 | 07:28 AM
Vtmbz's Avatar
Default New owner with transmission q’s
MY impeccable 1985 Mercedes is reserved for summer driving so I bought a 2005 xc90 for winter use and also to haul hay . All of my Mercs have suffered from the same problem at acquisition: neglected or deferred maintenance until they were no longer the cars that left Stuttgart. The task is always to bring them back from neglect, at which point they are a joy to drive.
On to the Volvo: 2005 xc90 awd. 5 cylinder engine. Timing belt has 20,000 mile on it. Has good response and shifts well ( at least I think so— my Merc shifts crisply while the VOlvo is rather softer. But no clunks or slips so far). This was a commuter on a dirt road. Probably needs new struts and springs as there is a camber problem on the front tires. Add to the list. It seems to have heavy steering btw— is this a trait or a problem?
Here’s the vin: YV1cz592651141266
Todays query is over the transmission. I want to either change the fluid and filter or have it flushed as its likely to never have been done. Based on the vin, what transmission do I have? Wikipedia returned me a trans that didnt seem right— AW40. Is this likely?
And the fun one: I cant find the dipstick to check the condition of the fluid! I promise not to over post in the future, but I’m orienting myself to this new and to me exotic platform: my Mercedes is all analog while this is all digital, and thats a big big change. Thanks in advance.
Old Oct 24, 2019 | 02:21 PM
you should see the yellow dipstick kind of hiding below/beside the lower radiator hose. See if this thread helps. Not sure if you are planning to do as a DIY or just reading up before having a shop do it...
https://www.matthewsvolvosite.com/fo...ic.php?t=64335
Old Oct 24, 2019 | 05:10 PM
Vtmbz's Avatar
Thanks for replying. First thing is do I have aw40 or 55-50. THen I want to check the condition of the fluid. I’ll look under there again but theres nothing yellow to be seen under all the grime so far.
Stratoblaster
Sep 2, 2024 11:18 AM
cbova
2001-2013 model year XC70
Nov 5, 2017 09:40 PM
marvinmartianx
Jul 31, 2017 05:53 PM
jarman66
Jan 12, 2014 09:32 AM
eichhoma
Jan 21, 2011 02:39 PM
