No Radio-CD player-2004 xc90
Old Jan 1, 2021 | 06:36 PM
lwelch39's Avatar
Default No Radio-CD player-2004 xc90
This car sat up for months, dead battery, I bought at auction, new battery, runs and drives fine... radio does not come on at all. occasionally the control head will light up, volume indicator, but will not indicate any volume level no matter what. Here's the odd thing: If you switch car off and on 6 or 7 times w/out cranking... the control head will come on then, but still no radio or cd will play. You can then drive, switch control off and on continually! I just wonder if whatever is keeping control from coming on ordinarily, is also keeping radio itself from coming on. Somebody must be familiar with the odd things of Volvo radios! Forgot to mention, the radio fuse was missing, I replaced it with hopes! but no... interesting the control head would come on w/fuse missing, made no difference when replaced.
Old Jan 2, 2021 | 03:39 PM
R2millers's Avatar
We have the same problem with our 2004 XC-90.
My mechanic who services primarily Volvo's, has to reprogram the console unit ( theft protection) with the radio to activate if the unit is replaced. These units are known for failure and buying one yourself without having it reprogrammed will not work.
You might have a unit replaced in your vehicle but not reprogrammed as it sounds just like ours after buying a unit on eBay but to no avail.
Good luck.
BTW, this tranny, if you have the 6 cylinder, are also pronged to fail after about 120k. Keep that tranny ATF changed regularly to hopefully extend its life expectancy
Iceman
Oct 11, 2021 03:19 PM
Tony Hill
2001-2013 model year XC70
Feb 23, 2019 09:26 AM
kapka42
Dec 26, 2011 11:11 AM
Costy
Apr 12, 2010 10:32 PM
mgreen2
Dec 24, 2008 04:31 PM
