not sure if maf is working on 04 xc90t6
Old Sep 12, 2016 | 12:56 AM
jim8923's Avatar
Default not sure if maf is working on 04 xc90t6
HI Guys, Maf problem in 2004 xc90t6 with 100k Went to clean the maf today i removed the sensor from the housing it is a bosch FOOC 2G2 065
when i looked at it i did not see the "U" shaped hot wire just a "V" shaped notches where it looks like a wire should be.
My question is should there be a exposed wire or not, and is the 065 the correct sensor for the 04 xc90t6???. Went to auto zone parts site thay show that the sensor and housing part # 0280 218 089 was used on other models and years volvos I would like to replace the sensor or at least know that i have the correct sensor. Does anyone have a cross-referance for the sensors. Ebay has many different part numbers and many different prices if you know witch ones interchange also is their a test for the sensor to be sure that I have a problem, assuming no problem with the wire. I cannot find a pic of the BOSCH FOOC 2G2 065 sensor showing both sides on the net to see if a exposed wire or not.
thx
jim
Kuromankuro
May 31, 2016 01:33 PM
richardgrant
Apr 28, 2015 08:22 PM
rspi
May 15, 2014 07:36 AM
BigAdam
Oct 21, 2008 10:01 AM
