P0420 + P0430 catalytic converter
Old Mar 9, 2019 | 07:09 PM
AmcMobE7T's Avatar
Default P0420 + P0430 catalytic converter
I just purchased a 2011 Volvo XC90 with 102k miles. I use 93 octane gas. On the drive home from the dealership, the check engine light came on. The ODB-II codes are P0420 and P0430:
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
Any thoughts on the most common cause of this in a 2011 XC90? Is it an O2 sensor fault? Mass Air Flow (MAF) sensor? Air intake leak? Or the catalytic converter (seems unlikely)?
Old Mar 10, 2019 | 11:54 AM
What engine does your car have? The P0420 code is saying there's too much of a differential between the front o2 sensor and the rear o2 sensor. This can be caused by an exhaust leak (particularly around the flex pipe) , an o2 sensor issue (typically the rear as the front controls the fuel mixture - which when off will throw other codes) or possibly an intake air leak or throttle body issues (less common). Anything else going on - ie driving in snow or rain etc? Did you try clearing the code to see if it returns (it may take 50 or so miles to reestablish).
Old Mar 11, 2019 | 04:43 AM
AmcMobE7T's Avatar
Thanks for the reply. Engine details:
2011 Volvo XC90 AWD, 6-speed automatic transmission
Engine code: 3.2 6-cyl B6324S
Engine size: 3,192 cc inline-6 (straight-6)
Engine type: gasoline, DOHC, naturally aspirated
Oil: 5W-30, 7.18 US qts (6.8 L)
I live in Pennsylvnia --there is some snow on the ground but the roads care clear.
I cleared the code using a Foxwell NT201 OBD2 scanner; the light went on again 8 miles later, this time with just the P0430 error.
The P0430 is what first lit up on the drive home from the dealership. I anticipate that the P0420 will light up soon as well --with a bit more driving.
etany
Apr 19, 2022 09:18 AM
yabadabadoo1026
Jul 18, 2019 11:02 AM
javpujol
2001-2013 model year XC70
Jun 21, 2019 12:32 PM
e.mence440
Apr 2, 2018 10:11 AM
Jon01V70
Nov 29, 2009 06:01 PM
