p2175 2006 XC90 4.4l
Old Oct 25, 2015 | 10:15 PM
backyardbill's Avatar
Default p2175 2006 XC90 4.4l
While waiting for control arms to arrive to fix front end problem, my wife announces a "limp home" problem. Arrrrr
P2175 Throttle Actuator Control System Low Airflow Detected
I can hear a kind of click/clunk coming from the throttle body (TB) while revving the engine. So I pull the throttle body and take it apart. The only thing I find is the stepper motor has a very slight play in the end bearing. I put it back together and temporarily mount it and plug in its electrical connector. With the KOEO, I have my wife operate the accelerator pedal. The TB butterfly opens and closes fully.
Hmmmm.
I hook up my bluetooth OBDII connector and turn on the Torque engine software on my Samsung tablet. The throttle position shows 27% when the pedal is at rest!
I'm thinking this is why the ecm thinks there is not enough air flow in the manifold when the throttle position is 27%. So it sets code p2175.
I pulled the accelerator pedal. When the pedal is pushed about 50% of it's travel, I can feel a resistance, like its hitting a stop, but then it gives and the pedal will go all the way to its stop.
Does anyone know how I can bench test this pedal assembly?
Any any other thoughts/advice would be appreciated.
Old Oct 29, 2015 | 08:59 PM
For those that are interested: this is a follow up.
I bought a used throttle pedal assembly off of eBay. It operated exactly the same as the one in my XC90. The bad reading of 27%-29% throttle position when at idle was due to a bug in the Torque software.
I cleaned the throttle body and put everything back together. I jumped the battery ( the battery was low but that's another story) and the engine fired right up. And the p2175 code was gone. And I didn't clear it with the scanner.
I drove it around for 15 minutes and it acted like nothing ever happened. I don't have a clue why ???????
Lastly,the info screen has "engine system service required". I have to research that now.
zral
Sep 27, 2009 01:48 AM
deemaz
Dec 19, 2008 10:13 AM
endlessct9a
Oct 29, 2008 01:22 AM
aquina
Jun 17, 2008 07:18 PM
