Possible oil leak in turbo?
First post on the Volvo forum, hopefully someone can give me some insight.
I have an 04 XC90 T6 with about 59K on the clock. I take very meticulous care of my XC and when I was wiping the engine bay down yesterday I noticed a faint, greasy film on the boost side rubber hose feeding into the intercooler. I disconnected the hose from the molded plastic tube that joins the rubber hose to the turbo.
When I looked into it I noticed a tell tale film of oil in the tube. I called a buddy of mine who knows alot about forced induction and he said it might be a leaking bearing in the turbo(s)or it may benormal for a small amount of oilto run through the system.
One thing I do know is that thehose from the molded plastic tube to the intercooler has a small hole if it is leaking a little oil onto the outside of thehose during boost. So my question is that is it normal for asmall amount ofoil to pass through the system or do I need to take it intoVolvo for warranty work?[:'(]
Thanks for any advice...
