Radio quit.
Old Mar 4, 2014 | 04:27 PM
ted123's Avatar
Default Radio quit.
This evening as I parked the 04/xc90, turned the key off and it sounded as if the radio was still on. Inserted the key and manually turned off the radio. Turned the vehicle back on, now the screen lights up with High Performance Sound and then turns back off. Any ideas on where to look.
Old Mar 6, 2014 | 07:43 AM
krsarpy's Avatar
Default radio quit
Check this link I posted in October, my radio is still working fine. Make sure if you remove and reinstall your radio, disconnect the battery after you put your Volvo in neutral. Hope this helps
https://volvoforums.com/forum/genera...io-info-74542/
Old Mar 7, 2014 | 09:55 AM
banyanleaf's Avatar
Thanks for the tip and I will try this weekend since it feels like spring now...
Old Mar 8, 2014 | 03:33 PM
ted123's Avatar
so on the following day on my way to work, the radio starts again and has been working now for two days, WTF.!!!
Old Mar 8, 2014 | 07:39 PM
banyanleaf's Avatar
I tried this morning. The CD changer has some CDs jammed inside. I couldn't figure how to remove the CDs. I made sure that all the connectors were plugged in correctly. No avail, the radio is still dead.
Old Mar 9, 2014 | 07:33 AM
krsarpy's Avatar
Default Plan
You may want to try the Ebay route, you can probably get a radio for around $300. However, you will need to check the part number on your unit to check compatibility for whatever you order. Your local Volvo dealership should be able to pull up the unlock codes for the radio on their data base. I believe the codes can be retrieved by VIN (Of the vehicle it was salvaged from) or radio ser#.
Old Nov 28, 2021 | 10:49 AM
willvan's Avatar
Mine did exact same ( High Performance ) message only. Replaced 30 amp blown fuse in half moon panel beside steering wheel and radio works great again
Magic_Don
Oct 1, 2012 04:56 PM
JimKW
May 11, 2007 07:42 AM
harbor
Jun 24, 2006 05:50 PM
95pimpwagon
Jan 20, 2006 01:09 PM
TylerG
Oct 10, 2005 01:16 PM
