Rattling sound from underneath
Old Jul 14, 2016 | 11:31 PM
rik881's Avatar
Default Rattling sound from underneath
My 05 T6 started making a rattling noise when accelerating smoothly, the transmission shifts fine so it should be something else, center drive shaft maybe? It is not very loud but annoying it is. The car was driven a few days with the right sway bar rubber and holder not in place. This might have something to do with it. Does anybody have a clue where i might start looking? Thanks in advance for any advice.
Old Jul 15, 2016 | 02:56 AM
Matt Fowler's Avatar
A good place to start is to check your drive axles for wear to the boots. making sure they are not torn or have become seperated from their "seats" where the clamps secure their ends to the axle. If you get debris inside those boots your car will make all kinds of fun noises. Ill attach some pics of what you DO and DONT want to see when you look in there. #1=BAD, #2=GOOD, #3=EPIC FAIL.....Hope I helped get you started. Good Luck.
Old Jul 15, 2016 | 08:56 PM
rik881's Avatar
Cv shafts are fine. I went underneath and the sound is coming from the drive shaft. I will have to pull the exhaust to get there. Has anyone ever repaired the center drive shaft?
Old Jul 16, 2016 | 03:34 AM
Carrier bearing maybe.
Old Jul 16, 2016 | 09:48 PM
rik881's Avatar
I think it is the bearing from the shaft to the transmission that's making noise. Is there DIY?
schwimms
Aug 6, 2011 05:43 PM
Chrisk1254
Jan 12, 2011 05:08 PM
dman777
Nov 21, 2010 08:57 PM
V70-T5
Jun 20, 2010 06:58 AM
jonnyboyca
Apr 9, 2008 10:29 AM
