remove bank2 exhaust manifold
4.4L V8
The main problem is p0430 code, bank2 cat efficiency. The oxygen sensors were not the problem. Using a stethoscope on the intermediate exhaust pipes: bank1 is nice and quiet while at idle and also while reving the engine; bank2 is very noisy at idle and while reving. The book says a clogged cat will cause p0430. And the sounds from bank2 appear to indicate clogging. BTW there are no other codes. I tried running cat cleaner in the fuel. Drove fro 250 miles. Code stayed off. Next day while drive, p0430 came back.
I'm deciding to pull bank2 exhaust manifold/cat and clean it or replace it with an aftermarket unit like this one Magnaflow Direct Fit Catalytic Converter 2005 2011 Volvo XC90 4 4L Manifold Rear | eBay
Is it possible to R&R the Bank2 exhaust manifold/cat without dropping the subframe (and everything else that is required as per Mitchel Pro Demand manual)? I have a fairly well equipped tool set from doing my own work for many years, but don't have all the special Volvo tools the Mitchel procedure requires.![Mad](https://volvoforums.com/forum/images/smilies/mad.gif)
Any advice or opinions would be very appreciated. Taking it to the dealer is out of the ($$$) question.
