Replacing Mass Air Flow Sensor
Old Mar 23, 2013 | 03:14 PM
Av8or's Avatar
Default Replacing Mass Air Flow Sensor
Okay so check engine light is on because the Mass Air flow inlet temperature sensor isn't working (integrated into the MAF). The MAF is riveted to a metal housing which the air passes through into the engine. Do I need to replace or remove the entire housing which it is rivetted to? Or can the replacement be done without this step?
EDIT: 2007 XC90 4.4L V8 Sport
Old Mar 25, 2013 | 04:57 PM
schumicat's Avatar
I'd find a picture of the part for your engine on ebay or rockauto.com etc. and see if you can tell whether it comes with the metal part attached to it.
cla6665
Jan 20, 2008 12:56 PM
jerryman
Oct 28, 2006 07:35 PM
volvogirl850
Sep 23, 2006 03:27 AM
reg
Jan 1, 2006 11:41 PM
floryed
Apr 14, 2005 10:51 AM
