Resetting Position Light Warning
Old Aug 9, 2011 | 11:47 AM
rfharper's Avatar
Default Resetting Position Light Warning
I just replaced position light bulb and need help resetting warning on dash.
Old Aug 10, 2011 | 03:52 AM
andreasb's Avatar
The warning should go away by itself if the bulbs are working. Did you put in LED bulbs? That will cause problems with the warning system.
Old Aug 10, 2011 | 06:21 PM
stonepa's Avatar
Just smack the offending light with your hand. Good chance that the bulb will light right up and the message will go away. The bulb holders don't do a great job with the bulbs they use in US spec cars. The bulbs loosen up and appear to be burned out.
patirwin
Oct 1, 2016 12:35 AM
mcknum7
Jan 30, 2014 12:08 PM
whome
Oct 24, 2008 05:17 PM
master_pre
Aug 21, 2006 09:01 AM
bongo240
Apr 1, 2004 06:33 PM
