rough idle, loss power...help ID a part
Old Jul 6, 2012 | 08:53 PM
Darin Schroeder's Avatar
Default rough idle, loss power...help ID a part
My 2004 XC90 T6 has been idling rough after it gets warmed up. If I turn the AC fan off, it helps. I though maybe it was my ETM, so I was going to try and locate it and clean it. In doing so, I found a part that was broken and I need to know what it is so I can replace it. I am hoping this will fix the problem with the Idling.
Description of part:
Has a 2 wire harness at the top, 3 hoses at the bottom. Part twists apart and has a diaphragm and a spring inside. This unit sits right to the left rear of the air filter housing.
I have currently "duct taped" this part back together and the idle seems to be doing better. I belief this part has something to do with a temp control or something.
thanks,
Darin
Wesley brown
Oct 7, 2014 10:12 AM
iamnickcarter
Jul 25, 2012 03:23 PM
hoodoo262
May 15, 2010 04:49 PM
markjenross
Nov 7, 2007 08:02 PM
markjenross
Sep 29, 2007 09:29 AM
