Squeal coming from engine compartment 2008 xc90
Old Nov 10, 2019 | 09:37 AM
Lance Lyons's Avatar
Default Squeal coming from engine compartment 2008 xc90
Hi, First time posting. My daughter's xc90 recently started squealing recently from the front of the motor near the pulley system. I have heard this before on other cars and it was typically the belt tensioner.
On her car, when she accelerates the sound goes away but when she coasts or comes to a stop it gets loud.
Does this sound like a belt tensioner? Should I replace this and the other 2 pulleys that arent part of a component (steering pump, a/c, etc).
Does anybody have a procedure or link to a video for this replacement?
Old Nov 10, 2019 | 04:31 PM
could be the tensioner, the pulley or one of the accessories. Which engine does your car have?
Old Nov 10, 2019 | 06:47 PM
She has the 3.2L. Looks like belts, tensioners, etc are all on the driver side.
Old Nov 10, 2019 | 08:23 PM
A couple of videos that seem to fit but not 100 percent sure yet.
and another that shows replacement of the serpentine belt.
Old Nov 11, 2019 | 06:47 PM
After digging into this a bit more I feel that I am able to do this job with about 60 dollars with a parts.
Fischer Tensioner
Idler pulley
Serpentine Belt
will need to remove Intake box and fuse box for more room
19mm wrench on tensioner to remove pressure
loosen A/C compressor and brackets and power steering reservoir to move out of way
disconnect water pump from pulley system to allow new serpentine belt
remove tensioner
remove idler pulley
replace tensioner with pin to lock it in position to not put tension on belt
route new belt in place
refasten A/C compressor and brackets
refasten water pump
install idler pulley
reinstall intake box and fuse box
does that sound about right? missing anything?
Old Nov 12, 2019 | 04:18 PM
sounds about right - its good to follow the Youtube vids or search for some posts talking through the procedure. You may also want to use a mechanic's stethescope or similar to listen and pinpoint the sound just in case its one of the accessories making the noise.
Old Nov 23, 2019 | 04:56 PM
The Only problem here was the Oil trap. I wish I would have known that. Pulled the oil fill plug and the noise goes away. No pulleys or tensioners, just the oil trap.
I wonder if there is a easy fix for that after spending $100 changing the tensioner and idler pulley/belt.
gordon368
Mar 16, 2017 07:04 PM
gdunican
Mar 17, 2015 10:40 PM
Sherry007
Feb 28, 2015 03:50 PM
webbch
2001-2013 model year V70
Oct 28, 2013 10:15 PM
rspi
May 2, 2013 01:45 PM
