08 xc90 Serpentine belt replacement
Old Jan 21, 2015 | 12:54 PM
gdunican's Avatar
Angry 08 xc90 Serpentine belt replacement
2008 XC90 Serpentine belt needs replacement (Tension pulley disintegrated!)...
Removed AC Pump and I removed the tension pulley assembly. I have the new belt, Idler pulley and Tension pulley.
I assume there is no way around NOT pulling the Power Steering pump?
Is there a link for the 2008 XC90 Belt Diagram??
Just looking for some quick advice. I live in Maine and unfortunately I do not have a heated garage.. :-( and it is a balmy 10 deg outside!
Thanks all.
Last edited by gdunican; Jan 21, 2015 at 12:55 PM. Reason: added request for diagram link
Old Jan 21, 2015 | 01:22 PM
ES6T's Avatar
Gotta pull the pump, unfortunately.
Old Jan 21, 2015 | 04:55 PM
gdunican's Avatar
Thank you... didn't take me long to figure that out, just had to thaw out a little first! LOL Thanks again. :-)
Old Jan 21, 2015 | 05:31 PM
JamesG's Avatar
Does this apply to the 3.2L I6? We have a 2007 XC90 3.2L I6.
Old Jan 21, 2015 | 08:18 PM
ES6T's Avatar
It applies to all the new SI6 motors with a belt driven power steering pump.
Old Mar 17, 2015 | 10:40 PM
KarlXC70's Avatar
Default serpentine belt xc90
How long did it take to replace the belt and idler? Have the same problem and not sure if should even attempt the job.
Tim Sway
2001-2013 model year V70
Apr 12, 2013 10:43 PM
jg1
Mar 8, 2010 08:09 PM
iscwebe
Feb 9, 2010 12:50 AM
lmchle
Apr 18, 2009 10:29 AM
tr_car_nut
Jan 24, 2008 05:50 PM
