Throttle Body Problems After Cleaning
Old Apr 16, 2015 | 07:01 PM
Ryan Baker's Avatar
Question Throttle Body Problems After Cleaning
I'm wondering if I ruined my throttle actuator while cleaning it. I had everything apart to put on a new oil trap so I decided to clean things out. Here are my codes. Your ideas and help are greatly appreciated. I had most of these codes before I did the the cleaning. I have looked at the translations, these are just the ones from my generic scanner. My vehicle is the 2.5L turbo
DTCs (Codes)
P1167 MOD $10
No DTC definition found. See service
manual
CONFIRMED
P2111 MOD $10
Throttle Actuator Control System - Stuck
Open
CONFIRMED
FREQ REPORTED FIXES
1-Repaired Engine
Control Module
(ECM) Connector
2-Replaced Throttle
Body
ALSO REPORTED FIXES
1-Relearned
Electronic
Throttle Actuator
(ETA)
2-Cleaned Throttle
Body
3-Performed Throttle
Body Cleaning
Procedure
4-Cleaned Throttle
Body Connector
P0036 MOD $10
Heated Oxygen Sensor Heater Control
Circuit Bank 1 Sensor 2
CONFIRMED
P2418 MOD $10
Evaporative Emission System Switching
Valve Control Circuit / Open
CONFIRMED
P2400 MOD $10
Evaporative Emission System Leak
Detection Pump Control Circuit / Open
CONFIRMED
FREQ REPORTED FIX
1-Replaced Leak
Detection Pump
(LDP)
P1167 MOD $10
manual
PENDING
P2111 MOD $10
Open
PENDING
FREQ REPORTED FIXES
1-Repaired Engine
Control Module
(ECM) Connector
2-Replaced Throttle
Body
ALSO REPORTED FIXES
1-Relearned
Electronic
Throttle Actuator
(ETA)
2-Cleaned Throttle
Body
Body Cleaning
Procedure
4-Cleaned Throttle
Body Connector
P0036 MOD $10
PENDING
P2418 MOD $10
PENDING
P2400 MOD $10
PENDING
FREQ REPORTED FIX
1-Replaced Leak
Detection Pump
(LDP)
Old Apr 16, 2015 | 07:03 PM
ES6T's Avatar
How did you clean it?
Old Apr 16, 2015 | 07:53 PM
Ryan Baker's Avatar
We used a product by Gum-Out it was called Air Intake and throttle body cleaner. We did have it completely off the vehicle. We sprayed that then scrubbed it with a tooth brush. The part that worried me was that my dad wanted to move the flapper to get some more of the gunk off. I'm wondering if that ruined the motor on it?
Old Apr 16, 2015 | 08:37 PM
ES6T's Avatar
Spraying it might have messed it up. You should spray a rag and wipe it and repeat until clean.
Old Apr 16, 2015 | 08:47 PM
Ryan Baker's Avatar
You think its a goner or do you think there is any hope of reviving it?
Old Apr 17, 2015 | 05:23 AM
ES6T's Avatar
Not sure how you would revive it. Did you clear the codes?
Old Apr 17, 2015 | 11:39 AM
Ryan Baker's Avatar
yeah just kind of wishful thinking. I didn't know if I could tear it all back apart and move the flapper back to the close position or not. I know that probably wouldn't fix it either, just more wishful thinking. The weird thing with the codes it wouldn't let me clear 2 of them. I have never ran into not being able to clear some codes. I've also never had my vehicles go into that reduced engine performance mode either. I didn't know if thats what made it unable to clear them or what.
Old Mar 16, 2019 | 08:03 AM
Tinysauto's Avatar
ha!! I just did that. Mines throwing the p2111 code. I can clear it, it runs fine, next key cycle comes back
Old Jun 19, 2020 | 09:23 PM
Angel Velasco's Avatar
I’m also having that issue. Just cleaned it. Start up rough idle, clear codes, runs perfectly. Did you ever find a solution
Mickdaddy
Jun 14, 2021 04:07 PM
tony1963
Jan 4, 2018 05:27 PM
mechanicnewbie
Jun 28, 2012 10:03 PM
triumph7
Mar 15, 2007 10:50 AM
T4
Sep 17, 2006 11:43 AM
