Cleaning Throttle Body
Old Jan 4, 2018 | 05:27 PM
tony1963's Avatar
Default Cleaning Throttle Body
I wanted to share with everyone a tip that I have used on several older Volvo models to take care of fault codes in the PCM.
These codes generally point to a mass airflow sensor but very little can ever go wrong with those. The occasional cleaning will usually take care of these for the life of the car.
Cleaning the throttle body (both sides) can get rid of codes and erratic idle problems. The engine computer sees a lack of airflow due to blockage around the throttle blades requiring that the blades open wider to get airflow.
The only way to clean a throttle body properly is to remove it and clean both sides, plus the edges.
treestone27
Apr 29, 2014 07:40 AM
go2sharks
Jan 21, 2009 10:24 PM
mturner333
Oct 18, 2005 09:21 PM
DanR
Sep 7, 2005 02:31 AM
proudmonkey
Jul 21, 2005 10:01 PM
