Tools needed to change brakes
Any one can list tools neded to change brakes on '05 XC90 V8?
I want to know what I need to remove the caliper bolts -torx or allen and what size.
I am going to do both front and rear brakes.
PS
I just ordered Akebono ceramic brake pads -can't stand the dust on 18" Atlantis wheels -those are not easy to clean.
Thx
PS
Thx
First, thanks for update.
Yes, I realized it from your previous posts (OEM parts are the best replacement-you cannot go wrong).
If you had to clean the wheels on Volvo cars, would you still recommend OEM pads?
PS
I am using Rybestos ceramic pads on my 850, they do not feel as "good" as OEM -takes more effort/pressure on the pedal, but-NO RIM CLEANING!
PSS
You would not remember if same socket is good for rear calipers on XC90?
Thanks again
PS
PSS
Thanks again
Akebono claims that their EURO pads are very gentle on rotors wear -is it an idication of the soft material?
They do feel "soft" -pedal does not need much pressure at all, and brakes feel no different from OEM. Maybe, the Rybestos pads are made of harder material - I did not even know about Akebono when I put Rybestos on my 850.
PS
Just checked -Akebono pads are available for 850 too, a bit more money then Rybestos.
PS
suprascooby22
02-22-2018 02:34 PM
