Turn signals
Old Jul 18, 2017 | 07:51 PM
Kamsmom92's Avatar
Default Turn signals
I'm in need of a desperate help both of my turn signals stopped working at the same time I located the fuse on the driver's side panel replaced it and they're still not working there not lighting up inside and they're not working outside
Old Jul 18, 2017 | 08:19 PM
madman77's Avatar
Question! was the fuse you removed bad? If so did the new fuse blow too?
Do your emergency flashers work? Could be something as simple as a bad flasher relay.
Old Aug 1, 2017 | 09:21 AM
ses_volvo's Avatar
I know both going out at the same time is a bit weird but new bulbs aren't very expensive and you'll probably need them eventually.
Why not start with new bulbs? Sometimes the simplest answer is correct.
studd34000
Jan 9, 2007 10:01 PM
autolampsplus
Dec 18, 2006 01:42 PM
RedBrick
Sep 16, 2006 09:06 PM
WagHag
Jun 26, 2006 09:43 PM
bpeabody
Aug 2, 2004 12:16 AM
