Used prestone radiator block leak
Old May 1, 2017 | 03:42 PM
Timeless_t's Avatar
Default Used prestone radiator block leak
I didn't know thathat I had a coolant problem till I saw a warning on my dash board. I brought my car to my mechanic and tells me that it's because of my radiator why I have a leak. And it's a very bad leak too. He tells me now he can't service the car till later on this week. Talked to my dad and told me to get a radiator block as a temp solution and I bought prestone radiator block with pellets and now even if my coolant tank is full it's still giving me the coolant low stop engine message on my dash board. The pellets haven't dissolved and it's still in my coolant tank. I think I just messed it up even more. How can I resolve this other than bringing it to the mechanic?
Old May 1, 2017 | 06:55 PM
ES6T's Avatar
Get that crap out of there. Hopefully it didn't mess up the level sender but it might have.
Old May 1, 2017 | 07:25 PM
Timeless_t's Avatar
Would you happen to know how I can take it out myself? Scoop it out I guess?
Old May 1, 2017 | 07:42 PM
ES6T's Avatar
How big are the pellets? Will a turkey baster work?
Old May 1, 2017 | 09:14 PM
Timeless_t's Avatar
It turned to like a pasty substance at the bottom of the tank. But I will try that. Thank you
Old May 1, 2017 | 09:21 PM
ES6T's Avatar
Might need to remove the tank and spray it out with a hose. Hopefully it didn't ruin your heater core, thermostat and/or water pump.
Old May 2, 2017 | 09:16 AM
Umbrella's Avatar
Here is a video on how to remove the coolant tank, so you can clean it out.
If you are unable to remove the tank than get a garden hose and put it in the tank and let it run for 10 minutes hopefully this will bubble out and flush most of the stop leak sediment out.To get buy till you go to the shop just carry plenty of water like 5 gallons with you and fill it up best you can, avoid overheating at all cost.
pyro71
Jun 22, 2014 01:16 PM
gquodala
Oct 11, 2013 02:55 PM
bassettsnose
Jan 6, 2011 03:18 AM
daver80
Sep 16, 2009 11:16 AM
sporky
May 24, 2008 09:40 PM
