What Yaw Sensors work?
Old Aug 6, 2016 | 01:44 PM
finding41's Avatar
Default What Yaw Sensors work?
Hi all. I'm a new 04 xc90 owner. Like all of you I need a yaw sensor.
I'm off to the auto recycler tomorrow and was wondering if other all wheel drive models had the same yaw sensor.
(If you have not fixed or modified your sunroof drains you will need to soon enough.) Replace that rubber L that the drain hose goes into and then into the A pillar. Mine was cracked and sticky it was so rotten. (I used a 3/8 piece of heater hose 5" long to fix mine. A little silicone on the joint and a ZipTie and we should be good for 12 more years at least.)
Thanks in advance!
GoVolvoParts
Mar 5, 2015 03:32 PM
Racho Kovacha
Aug 20, 2012 08:04 AM
PsIloveU
Nov 14, 2010 12:41 AM
Chriswheels
Apr 12, 2009 09:20 AM
Keggy
Apr 9, 2003 05:10 PM
