XC 90 Stalling daily while driving
Our XC90 2004 with 150,000 miles on it has been stalling out while driving. It starts back up again but it does this on the highway at normal driving speed. It does it 2 to 3 times a week and sometimes twice in the same day. We have taken it to the Volvo dealer and they say they can not find anything wrong with it. In my opinion, it is a major safety issue for myself those those driving with me on the highway. Any help appreciated.
Hi Penhookpete,
When you say stalling out, do you mean the vehicle goes dead abrubtly and then starts up again? Or do you experience a sputtering, a loss of power, the engine struggling to keep timing, and then it cuts out?
Stop by a auto parts store and have them check your battery, a drop in voltage can cause stalling. Not sure if your model has these issues but a failing fuel pump relay can cause random stalling issues with NO CEL.
If your vehicle cuts out quite suddenly, and starts up again (most of the time), I would agree with rspi about the fuel pump/ relay. This is the same problem I had a few years back. I had to replace fuel pump relay and did some re-wiring which had corroded.
I didn't know a dying battery (ie voltage irregularity) could cuase stalling..thanks for that rspi.
My daughter was driving her truck and it went dead while driving and didn't start back up. Its turning over but won't start. Can someone please help.
Thank you firebirdparts
I am having the same problem in my 2007 XC90 however it does not stall on the highway it stalls at low speed and normally the turning left and facing downhill.... it does not like reversing uphill when cold and cuts out. Can anyone help
Thank you all for the hundreds of complaints and corrective suggestions for Volvos that stall while driving.
It is scary to be driving along and suddenly the engine is dead, no power steering, tractor trailer bearing down in the rear view mirror.
The diagnostic shows
3A05 - fuel pump signal too low
and
DE42 - Communication with CRM control mode signal missing
Volvo dealership suggests changing the fuel injectors ??
$1000 to buy parts and $1000 labor
AND no forum contributor cites fuel injectors as the reason !!
Going to change out the fuel regulator, valve and fuel relay
Any thoughts on that fix??
And does anyone have any clue as to how Volvo is getting away with NOT fixing a design problem that will kill me??
Thanks
Mike J
and
Thanks
Mike J
and
Thanks
Mike J
and
Thanks
Mike J
Having read countless responses to this problem a common thread seems to be air getting into the fuel system, I have tightened the idle air hose and checked for leaks to the Throttle body and idle air motor. I know fro my army days many years ago diesels do not like air in the system so would check all hoses and connections. I have spent $1000's at garages trying to sort this out and sealing the air supply seems to be working
I see that another writer said she fixed stalling problem by fixing hole in air hose.
i will check.
though Seems strange that an air problem sends those that diagnostic messages that seem electrical fuel system issues.
Pty
This may be a unique problem but the key fob for our volvo had broken and the mechanism that flips the key out of the fob couldnt hold any weight. This with the added weight of additional keys and keyrings meant that with any taps or movement from my leg whilst driving, the key would turn off the car, even whilst driving on the motorway at one point.
We have removed all additional keys and there has been no problems with stalling and switching off whilst driving.
My 2004 XC90 T6 AWD had a similar stalling issue until I found that the upper motor mount (which had failed) had knocked a big chunk out of the plastic turbo plenum, thus an air leak... Would idle down to 500 on deceleration and die. Fixed the hole in the plenum and replaced the upper motor mount, and works fine now.
Just for anyone who might be having this problem, I wanted to add myself to the list of people who had a big chunk taken out of the plastic turbo tubing. That was the source of my issues too. Same spot.
Additionally it was sort of a two fold thing and i had the same issue as the guy with the keys and added weight causing the vehicle to cut out. After I had the turbo plastic replaced, my Volvo died on me again and I found out it was from bumping the heavy strap on my keys. I got rid of the extra weight and have been problem free for about 3 years now.
