xc90 awd rear end locks up
Old Jul 2, 2022 | 10:27 AM
anxov1es's Avatar
Default xc90 awd rear end locks up
2005 XC90 AWD: Occasionally, when I am backing up something in the rear end seems to try to lock up. It seems like it is skipping or what you would feel if a chain jumped a sprocket. If I rake the car out of reverse and then shift it back it works OK. Any ideas?
Old Jul 2, 2022 | 01:11 PM
Do you set the emergency brake when you park the car? If so next time don't set the brake when you park (if it's a relatively flat area) See if the noise occurs the next time you reverse.
Old Jul 2, 2022 | 02:16 PM
anxov1es's Avatar
No, it has always happened on level ground so far. It is almost like a gear problem in the differential or whatever they call it for AWD. But it drives perfectly in the forward gears and only deas it once in a while. Thanks for responding.
Old Jul 3, 2022 | 05:44 AM
Minmin123's Avatar
Your Haldex probably needs filter and fluid change.
cgerrells
Oct 30, 2018 07:04 PM
martino89
Jan 4, 2013 01:33 AM
sblaine
Feb 9, 2009 12:03 PM
timhixson
Jan 29, 2009 07:32 AM
Andrewde
Oct 30, 2008 12:51 PM
