View Poll Results: What's wrong?
Wheel Bearing
0%
Motor Mount
0%
Tranny
0%
Other -- post
100.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Xc90 clicking noise at low speed
Old Dec 28, 2009 | 09:59 PM
mcollard's Avatar
Default Xc90 clicking noise at low speed
Have seen a clicking noise at low speed. Seems to be coming from right side of car -- unsure.
I hear it while accelerating off a stop slowly say once a second.
Any suggestions on things to check?
Old Dec 31, 2009 | 05:14 PM
Volvotek's Avatar
brakes
Old Jan 13, 2010 | 08:47 PM
BikerJohn's Avatar
Could it be a stone in your curb-side tire?
Old Jan 14, 2010 | 09:41 AM
slowmod's Avatar
2nd that.. rotate the tires and see if the clicking moves- probably the easiest fix, check for bearing play while the car is in the air too.
I did have a similar issue in my 940turbo, that wound up being an inner axle bearing, which ultimately damaged the carrier.
Old Jan 15, 2010 | 08:24 AM
mcollard's Avatar
Have now rotated the tires.
I had replaced the wheel bearing on the rear passenger side a few months back, it's likely the front is beginning to go.
I'll jack it up and check the play. I bet it's exactly as you say.
Old Jan 15, 2010 | 06:25 PM
rx321's Avatar
If the noise is more noticable while turning AND accelerating, it's likely your CV Joint.
bsiwik4
Feb 1, 2016 05:13 PM
itr
Nov 22, 2010 07:05 PM
glenplake
May 10, 2009 11:58 AM
cjjtc
Feb 18, 2009 08:31 AM
elderzap
Nov 7, 2007 04:58 PM
