XC90 v8 engine fail
Old Aug 17, 2016 | 03:03 PM
jnor78's Avatar
Default XC90 v8 engine fail
Could anybody help me with this ?? Whats wrong ?
Old Aug 17, 2016 | 03:05 PM
ES6T's Avatar
Balance shaft bearing. I assume you have an early 2005?
Old Aug 17, 2016 | 03:15 PM
jnor78's Avatar
Considering buying..
is it possible to fix, or do I need a new engine ???
Old Aug 17, 2016 | 03:33 PM
Smith Volvo's Avatar
Banned
can be fixed - lots of labor
Old Aug 17, 2016 | 03:37 PM
ES6T's Avatar
Most are fixable. Won't know until you pull the head and inspect to see if the block is damaged. Then it needs an engine.
Old Aug 17, 2016 | 03:45 PM
Banned
I guess the issue is that water gets trapped in the valley and has no where to go damaging the balance shaft bearings. The later engines drained the water out better
Old Aug 17, 2016 | 03:52 PM
ES6T's Avatar
Yep. A drainage hole is drilled when replacing the bearing.
Old Aug 17, 2016 | 03:55 PM
jnor78's Avatar
I guess the seller tried to make the car look great...
Any one has the price for an engine change.. ?
Old Aug 17, 2016 | 06:36 PM
ES6T's Avatar
$14,000
Old Aug 18, 2016 | 05:22 AM
jnor78's Avatar
Thats with a brand new engine ??
Would it be possible to use a used 2006 engine instead ??
Old Aug 18, 2016 | 07:15 AM
ES6T's Avatar
Yes. And yes.
Roland9765
Aug 3, 2016 01:01 PM
joel12
Volvo C30
Nov 7, 2014 01:24 PM
tthrivi
Aug 11, 2007 10:07 AM
ALJOSEPH
Sep 6, 2006 07:01 PM
vvvolvo
Sep 4, 2005 01:27 AM
