West AK, CA, NV, OR, UT, HI, WA, ID
NO emissions, California smog test
Old Dec 11, 2018 | 05:20 AM
veltman's Avatar
Default NO emissions, California smog test
Regarding my 1982 Volvo 240 B21F9-CI, NO emissions are very high on the low speed 15 mph test, but nearly zero on the high speed 25 mph test after installing a new cat converter. I'm using 91 octane plus a few gallons of E85. All other emissions are very low. How can I reduce the low speed NO emissions?
Old Dec 11, 2018 | 06:18 PM
High NOs indicates high combustion temps - which is usually indicative of a lean condition or an overly advanced spark. I'd be looking for intake air leaks as I don't think the ignition timing is adjustable in your car. Given you say the NOs are high at low RPMs but come into spec at high RPMs, then an air leak (tubing, idle air valve etc) would make sense to me as the wider the throttle, the less impact a smallish leak would have.
holiday_wagon
Jul 7, 2011 06:53 PM
bossboy2
Jun 16, 2011 03:39 AM
emkay488
Nov 16, 2010 12:53 PM
mdsanders
Sep 11, 2010 02:31 PM
gitane59
Feb 14, 2010 04:54 AM
