West AK, CA, NV, OR, UT, HI, WA, ID
engine won't start 1990 740 4 door sedan
Old Mar 4, 2019 | 06:15 AM
Ken H's Avatar
Default engine won't start 1990 740 4 door sedan
I turn the key engine turns about 4 turns and stops, I do this 7 or 8 times engine won't start a friend gives me a jump thinking maybe low battery. In meantime, I have kept the throttle wide open now go back to 3 or 4 turns and stops. After 5 to 6 times, 1cylinder pops ahhh lt lives. I keep cranking it till it clears its throat and starts. I suspect it is in the key switch so I am going to run a jumper to the solenoid to a push button switch, to the positive and if it keeps cranking I will no it is the key switch THANKS but I think I solved the problem what do you guys think ???
Old Mar 5, 2019 | 02:41 PM
did you look at wiring diagrams to see if there's a relay in the path from the key to the starter? I doubt if Volvo would design the key switch to manage a lot of current - just the voltage to drive a relay. That's where I'd be looking.
Volvotips.com is a good site for an online repair manual and should have a wiring diagram.
Old Mar 6, 2019 | 05:35 PM
Ken H's Avatar
I ran a wire from the starter solenoid to a momentary on button, then to a positive wire I turned on the ignition hit the button and the engine starts so I believe the cranking problem is in the key switch cause the engine will keep cranking as long as I press the button with the ignition turned off Is there a mechanical choke or is it done through the computer and the injectors? I do believe the engine floods itself when it turns over 3 or 4 and quits through the ignition switch
BondoFox
Oct 22, 2022 07:54 PM
joe12willy
Apr 28, 2019 08:57 PM
RDSTHughes
Jan 11, 2014 08:27 AM
Lonestar of David
Jun 29, 2013 10:29 PM
