Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
Exhaust tip help
Old Apr 16, 2008 | 07:43 PM
Aftermidnight's Avatar
Default Exhaust tip help
Just picked up an Eurosport Tuning Exhaust tip to replace the rusty original on my 850.
Got the old one off but when trying to add the new one it is about 1-2 inches too long.
So what should I do next, lubricate the exhaust pipe, sand or trim it. Any ideas apreciated.
Thanks.
Posted in the wrong area, can someone move if needed.
Old Apr 16, 2008 | 08:25 PM
Default RE: Exhaust tip help
You mean it sticks out past the bumper?
If so maybe trim the pipe down a little to make the tip slide on more.
Old Apr 16, 2008 | 09:14 PM
yes out past the bumper.
Old Apr 16, 2008 | 09:49 PM
Try trimming the exhaust pipe on the car a little then it should slide in more.
Old Apr 16, 2008 | 10:21 PM
use a hacksaw?
Thanks.
Old Apr 17, 2008 | 01:53 AM
S70driver's Avatar
Agreed cut off the tailpipe first and then put it on.
Hacksaw should do it. Personally if you have access to one use a Plasma Cutter. Will make everything real easy and a plus a clean cut.
Old Apr 17, 2008 | 04:57 AM
a plasma cutter sounds nice but I don't have one.
Thanks for the replys.
Old Apr 17, 2008 | 01:05 PM
jks2's Avatar
You didn't get a plasma cutter with your box of Star Wars Cheerios?
Old Apr 17, 2008 | 01:46 PM
S70driver's Avatar
Mine came with a G.I. Joe lunch box.
Old Apr 17, 2008 | 06:57 PM
Or you can get a Tail pipe cutter really cheap from a place like Harbor freight.
Old Apr 17, 2008 | 09:23 PM
Jks2 too funny!
I got it on, I took it over to Midas and they welded it which looks 100 percent better
than the bolt on for only $10.00. I did error in still not getting it quiet deep enough,
I should have aligned it even with the opening but left it out a little. That is the
perfectionist in me. It does look just like their ad pic here:
http://www.eurosporttuning.ca/Mercha...Code=VL-850-en
I just want to say whoever designed the EST emblems did an amazing job (I put them
on the rear passenger windows, was surprised they had to go exterior).
Kitsune
Intake, Headers and Exhaust
Mar 9, 2010 03:40 AM
Fluxmotoring
Nov 18, 2008 02:53 PM
Patdon10
Sep 24, 2007 07:28 PM
thullz
May 31, 2006 05:14 PM
S70R
May 25, 2006 10:34 PM
