Canada, Over Seas & Elsewhere Not from the states? Everywhere else post here.
S60 heater ac inop 2002 PLEASE HELP
Old 12-15-2013, 05:29 AM
sismith73's Avatar
Default S60 heater ac inop 2002 PLEASE HELP
So battery died disconected charged re conected the wrong way as to say ignition was off not on postion 2. ccm has power going in nothing coming out no ac heated seats nothing. i say there is power going in but there are 2 red wires on 2 different wire looms 1 has power the other has not all fuses are OK re set several times to no avail. disconnected bat touch wires re connect with the key in position 2 took fuse 6-23 out cranked over nothing.
Old 12-23-2013, 03:04 PM
pierremcalpine's Avatar
If I understand your post correctly, you re-installed the battery but connected the terminals to the wrong poles on the battery? And now you are saying that CCM has power but no functionality...if that is the case, my suggestion would be to head to the junk yard to get another CCM and throw it in to see if the situation changes. If I've misinterpreted your post, can you clarify?
Old 12-23-2013, 08:48 PM
damien360's Avatar
If he gets another ccm then it still wouldn't work until he programmed the old one. I don't suggest doing that. Check power st the blower motor
fred666
07-15-2010 10:57 AM
burnferris
11-01-2007 09:27 AM
xjflexer
04-07-2007 06:31 AM
swedishbrick84
03-21-2007 05:18 AM
WAYNE
04-06-2005 10:46 PM
Quick Reply: S60 heater ac inop 2002 PLEASE HELP
