Bosch eta
Old 09-21-2016, 06:18 AM
George Overson's Avatar
Default Bosch eta
Hi everyone I have 2002 s60 2.0t se with 173000 on the clock I have had no problems with the car for the last four years but the other week my car went into limp mode I scanned it and it said throttle position sensor so I removed the bosch throttle and cleaned it out refitted it re scanned and cleared the fault code took car for a drive and it was brilliant two days after this I went to the car and it went into limp mode again say throttle position sensor I have another bosch eta coming will it need programming or just fitting and testing
Many thanks George Overson
Old 10-03-2016, 09:47 AM
Plenty of posts on ETM faults. As you've figured out if the cleaning doesn't work, you will need to replace the the ETM and get it reprogrammed to match your car. Did you check out Xemodex.com for getting your existing ETM repaired and preprogrammed?
Old 10-03-2016, 09:53 AM
Hi thanks for your reply I bought a second hand etm unit with the same serial numbers as mine I cleaned it all out fitted it to my car and it is perfect again no need to programme as my unit was a bosch one all I did after fitting was rescan and no faults found many thanks for your reply
sugardoo
10-20-2013 03:33 PM
condyboy
07-02-2008 03:35 PM
typhoon55
10-08-2007 08:44 AM
JBVolvo
04-20-2007 01:02 AM
Wheelyyy
03-05-2007 08:50 PM
Quick Reply: Bosch eta
