Shift indicator light?
Old Nov 21, 2008 | 03:44 PM
jwscott's Avatar
Default Shift indicator light?
Is there suppose to be an indicator light for the automatic transmission shifter? At night I can't see what gear I'm in without turning on the interior light. I bought the car used and it came this way. If there is a light, how do you replace the bulb? Thank you,
Jim
Old Nov 21, 2008 | 04:29 PM
billofdurham's Avatar
Default RE: Shift indicator light?
There should be a light.
Remove the side panel on the driver's side of the centre console. There is one screw towards the front, at the top of the panel. Pull the panel out with a twisting action then pull it backwards. Remove the tie strap and clips from the heater unit. Remove the bulb holder and bulb.
Reinstall in the reverse order.
Old Nov 24, 2008 | 05:58 PM
jwscott's Avatar
Thank you for the reply. I will try to look at it soon and see if I can get the side panel off.
Jim
Old Aug 28, 2010 | 11:39 AM
adan_j88's Avatar
Did it Work? can you explain me how to do it? I have the same problem on my 2002 S40
jsmoline
May 15, 2010 07:14 PM
jasongood
Jan 8, 2009 08:48 AM
colgate41
Jul 31, 2008 02:04 PM
s70familoy
Feb 21, 2006 01:43 AM
daisyifyoudo
Oct 29, 2005 05:19 PM
