Lola's Progress Log
Old Aug 3, 2009 | 06:41 PM
  #201
Legendsecko87's Avatar
I ended up getting Yokohama YK520's. They have a 520 tread life and a A;A rating for temp and traction.
Do you guys have any suggestions to air pressure I should run? I'm running 36 in both the front and the rear, although the computer said I should be running 41 in the back. Is that true?
Old Aug 3, 2009 | 08:14 PM
  #202
32 to 34 is fine. Just watch the tire wear.
Old Aug 3, 2009 | 09:32 PM
  #203
Sounds good. I looked online and said loaded they should be around 40, correct? I'm planning on doing that for the ride back home.
so after putting the MBC back in, I still cannot build adequate boost. What else could be the problem? The BPV is still good. Could the intercooler have a crack somewhere? Could fuel also be a problem? Perhaps my FPR is bad? Could it be fuel related?
Old Aug 3, 2009 | 09:44 PM
  #204
The intercooler could be cracked. Have you tried holding foot on brake and building boost and having someone feel around the hoses for leaks yet?
I would run 36 max loaded for the ride home.
Old Aug 4, 2009 | 01:38 PM
  #205
Not yet. I plan on pressurizing my intake system when i get home.
Could the problem be a stuck wastegate?
Old Aug 4, 2009 | 07:46 PM
  #206
Possible.
Old Aug 4, 2009 | 11:27 PM
  #207
Well I will look at the waste gate tomorrow. I made a small pressurizer that could be used by a bike pump and a lot of the rubber hoses are good, so no cracks. I was on the bottom and I noticed that I had a small hole or leak somewhere on the bottom. So I patched it up with some duct tape for the time being. If I was looking at it from the front It would be on the bottom left hand of the intercooler. Is that hole supposed to be there?
Old Aug 5, 2009 | 06:27 PM
  #208
Yes that is a drain hole for oil.
Old Aug 5, 2009 | 08:29 PM
  #209
Then that isn't it. Ugh :/
Old Aug 5, 2009 | 08:34 PM
  #210
LOL sorry!!!
Old Aug 5, 2009 | 10:07 PM
  #211
I checked all the hoses though! no problem! it has to be somewhere! :/
Old Aug 27, 2009 | 12:50 AM
  #212
Everything is working fine again. Just time to reset my MBC. Greatttttt
Old Aug 27, 2009 | 11:12 PM
  #213
Carrots's Avatar
Originally Posted by rspi
One thing I do not like about my 850 is something I knew before I bought it would bother me... The window switches being in the center console. I put everything there and no that I have an 850, everything is on the switches. Not to mention the fact that I have been putting things there for about 25 years.
So, to try to cure this situation, I believe I am going to try to install switches on my doors, like the rear doors have. Do you think this would be hard?
Easy way to fix this... get an S70
Sorry... just being a smartass. That window switch in the center console thing that European carmakers love to do has always bugged me, too... my Mercedes has them there, my old, old '87 Jetta had them there, and even the Saturn L- series (basically a slightly Americanized Opel Vectra) I'm fixing up as a fix it and sell it car has them there... it's a Euro- Quirk that kind of needs to go away...
Old Aug 28, 2009 | 03:09 AM
  #214
Meh, I kind of like it in the middle. Easy access, nice and simple layout.
My keyfob remote isn't working anymore... any ideas? I checked the fuse and that's still intact.
Old Aug 28, 2009 | 08:55 PM
  #215
Battery in the remote dead?
Old Aug 29, 2009 | 12:51 PM
  #216
I just replaced it :/
Old Aug 30, 2009 | 07:18 AM
  #217
Do you have a Dealer close? They can tell you if there is a signal coming out of the remote or not. They have a tool they can set the remote on and press a button and if the tool beeps the remote is good.
Old Aug 31, 2009 | 12:07 PM
  #218
I'll do that then. I have a dealer about a half hour away from where I live in Bellevue.
Old Aug 31, 2009 | 04:45 PM
  #219
meb7070's Avatar
did you try to reprogram the remote? Mine stopped working and did that and it worked again.
Old Aug 31, 2009 | 08:17 PM
  #220
Nope? Idk how.
