Removing the dash Pad (To replace the instrument panel lights)
Old Oct 27, 2008 | 08:21 PM
  #41
Default RE: Removing the dash Pad (To replace the instrument panel lights)
Not sure does it still show time and the back lighting dead?
Old Oct 28, 2008 | 07:41 PM
  #42
KubilayK's Avatar
Tech -
Just to verify. Is the hose at the back of the instrument panel for "turbo vacuum"? I need to disconnect it before I start repairing my odometer gear.
Old Oct 28, 2008 | 08:13 PM
  #43
That is the hose that feeds the turbo Boost guage.
Old Oct 28, 2008 | 09:43 PM
  #44
VJZ's Avatar
VJZ
ORIGINAL: tech
Time reads just fine. I just cant see it at night...lol
Old Oct 28, 2008 | 10:04 PM
  #45
Quick Brick's Avatar
Hey now VJZ,
It seems that the bulb is dead.
To remove the dash pad is easy and will take you no more than 30 minutes start to stop.
The bulbs are very easy to replace and there are two clamps on top of the cluster that just pop off.
Just be careful of the trip reset pushbutton upon removal and replacement. You dont want to break or bend it.
The photos didnt arrange the way I wanted, but youll get the idea.
http://s286.photobucket.com/albums/l...view=slideshow
[sm=icon_cheers.gif]
Old Nov 2, 2008 | 03:51 PM
  #46
KubilayK's Avatar
ORIGINAL: VJZ
I'm going to be doing a dash conversion to LED's soon.
I don't know what color to go with.
Probably cool white numbers with Blue needles.
Where are you going to buy the Leds? I am ready to replace mines since my dash is already opened up for my odomoter gear replacement. Thanks.
Old Nov 4, 2008 | 11:03 AM
  #47
Hello VJZ,
Please take a few pics of your project as it sounds very cool(blue) and Id like to do something similar. Our dash is kind of dark isnt it? Better with the trip computer light working again but a little more wouldnt hurt.
Looking forward to your completion.
Old Nov 10, 2008 | 08:26 PM
  #48
KubilayK's Avatar
No place to buy any LEDs? Nobody?
Old Nov 10, 2008 | 08:51 PM
  #49
Check here. http://www.superbrightleds.com/specs/74_t15.htm
Old Nov 11, 2008 | 06:30 PM
  #50
KubilayK's Avatar
Can I use them to replace 4 big instrument panel bulbs? Is there anybody tried that?
Old Nov 11, 2008 | 07:27 PM
  #51
You will need the 194 style bulbs. I wanted to try them but haven't had the spare cash to try them.
Old Nov 12, 2008 | 08:03 PM
  #52
KubilayK's Avatar
OK. It's getting complicated here. i dont want to make a mistake since after I close everything I do not want to open again :-) That would be a nightmare after closing the dash, you end up with a dark instrument panel.
Here are my findings:
1 - Four big bulbs behind the speedometer and RPM gauge - WLED-x4 LED bulb (#194)
2 -The small ones behind check engine light area- B8.5D Twist Lock lamp
3 -The ones that go to the underneath to the heated seat switch - NeoWedge Instrument LED bulb
I am not sure about soem of those, such as T1.5-x Instrument LED bulb.
Old Nov 13, 2008 | 07:21 AM
  #53
I think those are them.
Put all of the bulbs in and just set the top dash part on and plug the air bag in and turn the key on and check everything.
As long as the air bag is plugged in you will not set any codes in the SRS system.
Old Nov 15, 2008 | 05:52 PM
  #54
KubilayK's Avatar
I gave up. I just installed the regular bulbs. A/T bulb still does not work. At least my odometer works now. It was hard work.
Old Dec 30, 2008 | 12:34 PM
  #55
96 850's Avatar
Yourpictures are a great help! So, does the light for the clock require a special bulb as does the one with the trip computer? If so, what kind of bulb is needed? It is probably best to replace all the instrument bulbs at one time while you have it apart. Can you provide all the bulb numbers and locations in the instrument cluster?
Thank you in advance!
Old Dec 30, 2008 | 03:41 PM
  #56
There is 4 bigger ones that are 194 bulbs. The clock and trip computer if you have one are smaller bulbs that are soldered into a base.
Some have found the bulbs else where. For me I think I would just pay the $7.00 each and be done to not have to deal with the soldering and stuff.
Old Dec 12, 2010 | 03:20 PM
  #57
FASTER's Avatar
ok just ordered my gear, while im at it the led display dosent light up where it shows gas mileage and temperature outside and so on, is there supposed to be a light for that,I'd like to get that working before I reassemble everything when the time comes to change it all out. Thanks
Old Dec 12, 2010 | 10:05 PM
  #58
Henry10's Avatar
LED Display is the twist bulb+socket. You should have a bunch of these. See the above messages for the spec on this Bulb, although I have not personally verified it.
What I do know is that you can get these bulbs at any auto parts store that sells parts for European cars. I could not find at Advance Auto Parts or Autozone. When I fixed my odometer, I had some bulbs left over from my previous Mercedes, so I replaced some burnt ones.
I had bought these bulbs atSnitzel's Foreign Car Parts, 161 West Main Street, Clinton, CT 06414, 860-669-5733. Ask them Instrument Cluster lights. I think I paid $ 5 for 6-pack, but I could be wrong -- it was 3-4 years ago. The store though is still there.
I tried the DIY fix, but they were not like the ones used for example on the dash switches (eg. headlight switch, fog lights, Tracs, etc). These latter ones are found at Radio Shack, Part Number 272-1092 ($ 1.99 for 2-pack). Just use a small flat-head screwdriver (or pointy kitchen knife will do), remove the 2 wires from slots in the socket and pull it. You do need good eyes or a magnifying glass. Some could be so burnt that you need to break the bulb to remove them from the socket. They are kept there only by the wires. Don't try to pull without unwinding the 2 wires, because you may break the socket which is the most important part actually.
Old Jul 19, 2011 | 08:29 PM
  #59
clean850R's Avatar
Ok so I tried to get this pad out! Something on the passenger side is holding me up? Does the airbag come out separately or with the pad? Seems to be where I'm stuck! Took out the 4 10mm bolts, and the one under the speaker grill? Anyone have this issue? What could be holding it on?
Old Jul 19, 2011 | 11:58 PM
  #60
Vmax's Avatar
The airbag comes out with the dash as one, there is a small green clip that goes into the airbag connector under the airbag assembly itself.
First make sure all the screws behind the airvents are removed. To remove the airvents just turn them down, get ur fingers wedged at the top, and pull briskly but carefully, they pop right out to reveal the screws.
The far passenger side vent needs to be pulled out before the dash can be removed. It has no screws behind it.
Let me know if you need more help
