What did you do to your car today?
Old Dec 20, 2012 | 04:06 AM
  #981
blackcomb1's Avatar
I drove mine
Old Dec 20, 2012 | 05:18 AM
  #982
Kuda's Avatar
850R
Yesterday
new 3inch freeflow with cowley performance boxes. car still had the original pipe from factory on. i nearly fainted.
Volvo spark plugs
Today
New brake pads all round and again a session on the seats and all interior to get this car clean.
Old Dec 22, 2012 | 11:37 AM
  #983
Kuda's Avatar
S60 - New MAF
850R - replaced the PCV system
Old Dec 23, 2012 | 04:35 PM
  #984
predxen's Avatar
Started lapping valves and replacing valve stem seals. Cylinder #1 is done, 4 to go.
Old Dec 23, 2012 | 08:59 PM
  #985
S70: Removed the headlight wiper stop, since this car has no wipers.
- Installed a Antenna Label on the antenna swith I installed some time ago.
- Replaced the antenna (the mass was broken).
- Washed it.
Old Dec 23, 2012 | 10:01 PM
  #986
chrispy960's Avatar
Put my new to me 1997 960 wagon on the lift for the first time to inspect it. For 239,000 miles, I'm really impressed with this car, especially being a New England car. No rust anywhere on the body or underneath., no leaks or oil stains. Car is in overall great shape for it's age. I did find a broken driver's side sway bar link, New pads needed all around and a small patchable hole in the pipe before the catalyst. Struts on the to do list after I fix what I found today and the timing belt replacement.
Old Dec 25, 2012 | 09:04 PM
  #987
S70:
- Replaced CV boots.
- Replaced front brake lines.
- Replaced rear rotors.
- Changed oil and filter.
Old Dec 28, 2012 | 09:42 AM
  #988
Kuda's Avatar
850R
Changed Oil and filter
Flushed tranny and new juice
S60
Repaired passenger door handle
Old Dec 30, 2012 | 10:09 PM
  #989
Changed the thermostat in the 850. Running between 188° and 195° now. Was running as low as 158° to 167°.
Old Dec 31, 2012 | 06:05 AM
  #990
04.5s40's Avatar
^Good, to hear its running better!
Old Jan 1, 2013 | 08:42 AM
  #991
MSGTUSMC's Avatar
rspi - you are going to have a new vehicle when you finish replacing each part! Happy New Year!
Old Jan 1, 2013 | 09:11 AM
  #992
Happy New Year to you to man. I think I'll change my signature to read '11 Volvo 850 T-5R. lol
Old Jan 3, 2013 | 06:57 PM
  #993
On the S70...:
- Changed the battery with one from the junk yard. It had a 6/12 sticker on it.
- Un-jammed the rear passenger side door and replaced the latch with one from the junk yard.
- Replaced the washer nozzels with the '99 fan style (also from the jy doner car).
- Glued the door clip brackets back in with liquid nail.
- Replaced the driver side from corner light with a used one (from that jy doner car). I broke it cleaning ice off the front of the car the other day.
Old Jan 6, 2013 | 02:07 PM
  #994
Cleaned out the wagon and de-odorized it with my Ozone machine.
Old Jan 6, 2013 | 11:30 PM
  #995
Handysmurf's Avatar
I changed the odometer gear in my car today. It went smoothly and worked out successfully, but what a pain in the neck for such a teeny, tiny little part.
I also had to reset the driver's side temperature control cable down at the box end so the **** turned smoothly throughout the whole range of temperature selection. MUCH less of a P.I.T.A.
Old Jan 7, 2013 | 01:53 AM
  #996
alinazhou's Avatar
Banned
changed oil and my car then put wheel cylinders on my car
Old Jan 7, 2013 | 02:08 AM
  #997
Kuda's Avatar
Going to drive the 850R hard today till something break cause this car is so neglected i need to get the worst out first.
Going to go shopping for possible a brand new 19T and everything else that i can replace with that the same time.
If enough time i will go get quote for the wash and ion ( bodywork repairs) today as well.
Old Jan 7, 2013 | 09:07 AM
  #998
chrispy960's Avatar
Changed out the timing belt, water pump and all of the tensioners and pulleys that go round and round. Also replaced the rear pads and air filter.
Next up - front pads, spark plugs, oil change and sway bar link ends.
Old Jan 9, 2013 | 04:50 PM
  #999
Handysmurf's Avatar
What did I do to my car today ?
....I'll give you a hint ...
The projector lights are MASSIVELY better then the stock lights. :-)
Old Jan 9, 2013 | 04:55 PM
  #1000
See, that's what I put on my Christmas wish list and no one sent me a pair.
