Dash board removal for mounting tab repair
Old Oct 30, 2013 | 05:26 AM
  #101
redikqliss's Avatar
Ahh, good point. Now a cowrkr also ran by me that i could possibly try gorilla glue, again with that i wud have to keep pressure on the dash till it dries.
Old Oct 30, 2013 | 05:28 AM
  #102
redikqliss's Avatar
Another idea was to perhaps brace the dash? And being im only loose on the driver side id only really hav to focus on securing that end. Any thoughts? I really appr. the feedback =D
Old Dec 13, 2013 | 08:44 PM
  #103
cdnbluez's Avatar
I had 2 broken tabs. Removed the screws under the wiper plastic cover. Got a can of spray foam insulation. Inserted the tube into the screw hole and shot some foam in. The foam expands and hardens, no more squeaks.
Old Dec 13, 2013 | 08:45 PM
  #104
I actually thought about doing that but chickened out. LOL
Old Dec 13, 2013 | 08:53 PM
  #105
Old Oct 10, 2017 | 09:43 AM
  #106
800artfreed's Avatar
Default Testing Repair for Lower Dash
Recently after damaging my dashboard I found a replacement at a parts recycle yard. Two of the tabs were broken off and a third was cracked. All the pieces were large and not missing. I used "plastic welding" to reattach the parts to the dash. Please search on the web for plastic welding. On youtube I found this video instructive,
There are other videos as well.
I purchased a 30 watt soldering iron from Harbor Freight. I cut off the shaft of a cheap small screw driver to create a flat welding tip for the iron. I also used black as well as "clear" tie wraps for sources of filler material.
The repairs look ugly but it is much less work than using epoxy (my previous repair). I have to swap out the bastardized harness on this dash with one from my left over dash. I will let you know how long the repair holds up. Flexing the repair by hand the repair seems strong. Remember this is a compression stressed attachment on the car.
The screw holder was somewhat tedious as you must slowly build up the material. I will drill a pilot hole for the screw so as not to crack the repair.
Good Luck.
1998 S70-T5 201,000 miles
Attached Thumbnails  Dash board removal for mounting tab repair-right-hand-tab-broken-base.jpg    Dash board removal for mounting tab repair-rebuilt-screw-holder-driver-kick-panel.jpg
Ahmed
Nov 7, 2014 05:14 PM
rcvolvo
Mar 26, 2013 12:52 PM
heavyphantom
Nov 16, 2008 08:54 AM
deathbots
Jul 22, 2007 10:06 PM
