1998 S70 Not starting
Old Oct 17, 2017 | 05:52 PM
jpirish's Avatar
Default 1998 S70 Not starting
It started with the car just stalling while driving. I replaced the fuel pump relay 2 times and it started right back up. 3rd time it stalled nothing worked .Time to get a tow home. The only way I can get 12 volts
on the fuel pump connector is to run a jump wire strait from the battery to # 87 on the pin were the fuel pump relay goes. I tried jumping #15 & #87. I get no 12 volts at the plug for the fuel pump. I changed the fuel pump and the throttle body sensor & the air control valve also. Also ignition switch assembly.
Help
jpirish
91 240 173K
2 98 XC
1 98 S70
Old Oct 18, 2017 | 07:46 AM
Psaboic's Avatar
Sounds like it could be a wiring issue. Most likely from the ignition switch to pin 87 on the pump relay. One thing you could try is remove the computer module and reseat it. Probably won't fix the issue, but definitely worth a shot.
Old Oct 19, 2017 | 05:45 PM
jpirish's Avatar
Default Got IT :)
Changed ignition switch again . Bang pump worked. Junk Yard Parts 10.00
Thanks
Jpirish
Old Oct 20, 2017 | 09:01 PM
Psaboic's Avatar
Well, I was close <grin> Glad you fixed it!!
yanhor15
Apr 27, 2015 01:44 PM
delsa
Mar 21, 2008 11:35 AM
redlight
Mar 6, 2008 05:23 AM
starfighter
Aug 1, 2005 02:47 PM
