shift bypass button
Old Jul 25, 2005 | 09:36 PM
fast850r's Avatar
Default shift bypass button
I just purchased a 95 850R. I have to push the button every time I want to get out of Park. Is this normal, and if not, how can it be fixed?
Old Jul 25, 2005 | 09:44 PM
Default RE: shift bypass button
The shiftlock micro switch is bad.
Try searching around this forum in the 850 section I have posted how to replace it and there should be a couple of pics that will help.
Old Jul 26, 2005 | 09:48 AM
JimKW's Avatar
Here is the information you need on changing the microswitch. Look at the directions at volvospeed.com, but look for the part that I got. It had the microswitch and selenoid all in in one. It's a pain to do because of where it is located and it's very small. Watch very carfully how the old one is in there and make sure you put the new one in the same way.
https://volvoforums.com/m_8961/tm.htm
newmex999
Aug 20, 2014 02:29 PM
schmuecker
May 19, 2011 06:45 PM
elcs70
Feb 12, 2011 07:40 PM
volvoist3021
Jul 31, 2009 01:01 PM
ross83
Dec 4, 2008 03:55 AM
