Volvo 765 RPM engine problem
Old Aug 10, 2005 | 05:42 AM
jaapfijn's Avatar
Default Volvo 765 RPM engine problem
Hi
I have an Volvo 765 (1989) an i have a problem with the engine. When I am driving sometimes the Rpm goes automaticly to 2500/3000 rpm.
Does anybody has an idee what this can be
Old Aug 11, 2005 | 12:29 AM
Default RE: Volvo 765 RPM engine problem
Check good for vaccum leaks.If no leaks check the idle motor.
Old Aug 11, 2005 | 02:28 PM
jaapfijn's Avatar
Thank you for your advice, I will look to it but i still have a question when it is an vacuum problem isn't it strange that it not always some day i do not have any problem at all. And my other question what do you mean by the idle motor and where is it. I have a langue problem because i am dutch.
Old Aug 11, 2005 | 09:51 PM
It could also be a bad brake booster.When you hit the brakes then diaphram moves and sometimes it will leak and others it won't.
The idle motor is under the throttle body follow a hose from the induction hose to the idle motor.It looks like a cylinder with 2 hoses going to it.
danutm
Mar 4, 2010 06:08 PM
lummert
Feb 22, 2008 04:45 PM
lummert
Feb 9, 2008 10:00 PM
lummert
Feb 8, 2008 10:57 PM
