Engine smoking, and claping noise under the hood
Old Sep 26, 2008 | 10:33 AM
RuslikUA's Avatar
Default Engine smoking, and claping noise under the hood
Hello. Anyone who knows about volvo engines plz help me out.. I got 2001 Volvo C70, and yesterday I went to start the engine, and I heard a clapping noice from under the hood, and when I got out, I saw that my car is smoking with alot of white smoke.. So I shut of the engine, checked the oil, and it seemed to be below the level... I got this car off auction as is, for 2500$, bcuz it was in accident and I thought that only it was hit inisrear wheel. Some ppl told me I have to check compression on the cylinders, and if that is not a problem than thats turbo... anyone can help?!
Old Sep 26, 2008 | 05:02 PM
PANTYEATR's Avatar
Default RE: Engine smoking, and claping noise under the hood
i had that happen to me and it was my thermostat.
check and see if the fans are running when it's about to overheat
check and see if the coolant in the reserve bottle is bubbling.
Old Sep 26, 2008 | 08:09 PM
Make sure the timing belt isn't coming through the timing cover.
Old Sep 26, 2008 | 10:30 PM
PANTYEATR's Avatar
ORIGINAL: tech
hahahaha yeah like mine did months after the thermostat
Old Sep 29, 2008 | 11:10 AM
RuslikUA's Avatar
well it's not belt or thermostat, bcuz I checked the cylinder pressure and all 4 show 155psi, and the one one the very left shows 130-135psi, so I would say it's eather valve, cuz it makes some noise, or head gasket, and it evenleaks oil sometimes..[X(]
Old Sep 30, 2008 | 05:58 PM
Then maybe the lifters are making noise and you need the oil pan o-rings replaced.
Those pressure numbers aren't that bad.
Old Oct 9, 2008 | 01:08 PM
RuslikUA's Avatar
the oil pan had hole on the buttom acctually, and I was wondering where the oil is coming from. I took off the pan, and gonna have it welded in my college.. Do u guys think that something has been messed up while the car been driven with just little oil..? do u guys know how to get to the radiator in those cars?
Old Oct 9, 2008 | 02:39 PM
The radaitor has to come out the bottom.
There might be damage but only real way to find out is to install it after it is fixed and start it.
Old Oct 15, 2008 | 12:55 PM
RuslikUA's Avatar
ok,i got my oil pan welded,installed it, put in 5quarts of 10w40, and after starting it, the noise dissapeared for a while than came back, and when I took out the dip stick, the oil was bubbly, and the turbo was smoking... i m really dissapointed now, acctually thinking about swapping the engine, which gonna cost around 2k, plus installation...
Old Oct 15, 2008 | 01:08 PM
But did you drive it afterwords?
If not drive it some the noise should go away.
Also for the smoke is the vent system clogged?
Old Oct 15, 2008 | 03:32 PM
RuslikUA's Avatar
maybe the timing belt is not aligned... how do u align it???
Old Oct 15, 2008 | 05:55 PM
http://www.babcox.com/editorial/ic/ic60326.htm
Old Oct 16, 2008 | 01:22 PM
RuslikUA's Avatar
I think I m gonna replace my engine, what u guys think about this price, $1000 with 67k mileage, with turbo included. I bought instructions repair manual DVD on ebay, any tips, or what are the harder parts?
Old Oct 31, 2008 | 11:27 AM
RuslikUA's Avatar
I bought another engine and I think that company gave me newer engine that I purchased,My car is01 Volvo C70 2.3 turbo, and they gave me engine from 04 Volvo V60 2.4 with less mileage that I bought, and turbo that they gave me was from 99 Volvo V70; ...
Should I use my own turbo, but it was smoking, and do you guys think the engine will work, if all the mounting points are the same, and BTW what service would be good to do before putting the new engine in, it has 56k (timing belt, water pump, etc.)? Thanks for your help
Old Oct 31, 2008 | 11:52 AM
Is the S60 motor a turbo motor?
Old Oct 31, 2008 | 12:33 PM
RuslikUA's Avatar
I have no idea... the vin number from V60 is #YV1RS64A242367560
and it says on the paper they attached \2.4, A5, CAL, FWD, 56K, 190X5, RIV
Old Oct 31, 2008 | 12:42 PM
That is a Non-turbo motor. If you have a C70 you have a turbo motor and that one won't work.
Old Oct 31, 2008 | 12:50 PM
RuslikUA's Avatar
ok.. time to exchange than.. those guys are retards... I found out at home that the stock number was different on that engine.. but they close too early so couln't go back.. will do it today or tommorow I guess...
Old Oct 31, 2008 | 02:02 PM
RuslikUA's Avatar
one more question.. my right rear wheel was hit, and bent toward under the car, what would be the most it could cost me to replace that, or what exactly the parts I should be looking for? thanks.
Old Oct 31, 2008 | 02:13 PM
It just the rim bent?
Many things under there could be bent best would be to have someone look it over.
