rattle/squeaks from rear cargo area
Old Nov 5, 2008 | 08:18 PM
Randolf's Avatar
Default rattle/squeaks from rear cargo area
seems to be excessive noise in the form of rattles and squeaks in the cargo area
dealer told me it was cargo cover so i drove without that for awhile to no avail
also have (bought aftermarket genuine volvo) metal cargo divider the kind that can flip up to the ceiling
when not in use,however it seems rock solid regardless of which way i try to move it
cargo under floor is empty
spare tire is firmly fastened down
i am stumped any new ideas?? thanks
Old Nov 5, 2008 | 10:28 PM
sporky's Avatar
Default RE: rattle/squeaks from rear cargo area
Could be the door panel rattling around. Lots of posts on this website on how to fix if that is your problem.
Old Nov 5, 2008 | 11:14 PM
bjornagain's Avatar
2 Other areas worth checking... if you have a 7 seater, check that the rattle etc. isn't from that area but the main other squeak culprit in these models is the latch and pin that locks the rear seats upright. If these get slightly worn or are not properly and tightly adjusted, they can cause the most annoying squeak! Easy to check this one... just fold seats down and drive and see if the noise goes!
Old Nov 11, 2008 | 02:44 PM
jeffmills6's Avatar
I don't know what year your v70 is, but on my '99 I get a rattle and squeak from the rear seat back where it locks in the up position. It ratlles back and forth on the locking pin as I drive. Annoying. I'm going to find a way to adjust the hook that locks the seat on the pin (I hope)
Old Mar 25, 2009 | 04:37 PM
Tarquin's Avatar
I had the same problem on my 850. Turns out it was where the seat engages with the latch. I saw a number of suggested remedies including 1 that suggested melting candle wax over the latch pin. In the end I wound electrical tape around the latch and it's been quiet for the last 3 months. Cost to fix - nowt!
Hope this does the job.
kittyhazelton
2001-2013 model year V70
Sep 30, 2014 02:03 PM
Gr8lite
Jul 28, 2011 01:04 PM
sundance
Oct 2, 2009 06:32 PM
lowbeer
Oct 25, 2007 08:30 AM
rtarabou
Dec 6, 2005 09:08 PM
