S60R clunk noise
Old Dec 19, 2008 | 03:48 PM
KeitaS60R's Avatar
Default S60R clunk noise
Hey Tech or anyone, i have a clunk/click noise that just stared today out of no where as i drive. bought car off lot last week 72k miles. when i come off the accel it makes the noise and then a times when i depress the clutch slower speeds. no wheel vibrations so i ruled out CV shafts and tire rods. anyone know what this could be, and secondly if i cant get to a shop for 3 days should i be ok to drive?? i had the car jacked up a few days ago and no noise until today, 3 days later! car shifts fine so i didnt think it was a transmission issue either.
Old Dec 19, 2008 | 06:03 PM
keesue's Avatar
Default RE: S60R clunk noise
Based on my experience, the suspension control rods in the rear have ends on them that wear out. This causes a clunking noise when coming off the throttle and also can be heard when getting into it (but harder to hear due the engine). I just was made aware of this by my dealer who wanted a princely sum to replace them. I'm going to jack it up and see what's what and report back.
Old Dec 19, 2008 | 06:36 PM
Also check the engine mounts espically the upper and lower torque mounts.
Old Jan 13, 2009 | 08:47 AM
las4444's Avatar
Has anyone be able to update? I just started to notice this on my 2004 s60r with 63k. I really notice it when shifting out of 1st and 2nd gear.
Old Aug 28, 2010 | 09:55 PM
Richr1's Avatar
Okay Guys, I have an 07 and that very noise is coming from the front and its bad real bad. It only has 34K and I'm not happy.
I brought it to the dealer and they tried replacing the angle gear bolts with ones off a XC90 AWD (its a heaver car). Its not as bad but, it sound like it's only coming from the drivers side now. I ran it hard for half a day and I believe the sound is creeping back.
I will not increase the HP (ECU upgrade) till this is resolved however....
Can anyone else through out more ideas. I'm sure its happening to others......
Old Aug 28, 2010 | 10:09 PM
Richr1's Avatar
I forgot this tidbit the tech is correct. I called IPD and they said:
1) Check or replace fluid in angle gear
2) Inspect or replace the upper and lower stablizer mounts
3) Inspect or replace the transmission stablizer mount
IPD carries a better harder bushing that woun't ware out as quick.
Still my question why is this happing at 34K Administrator?
Your thoughts please......
Old Aug 29, 2010 | 08:50 PM
Manu Noypi's Avatar
Also check the contro arm bushing. These cars are know to have bad bushings. I already changed mine.
Guy_Driving_A_V40
Feb 16, 2013 03:16 PM
evlwhtguy
Sep 28, 2012 06:24 AM
Audie1966
May 18, 2012 09:34 PM
beazy22
Feb 13, 2011 05:46 PM
bbernard
Aug 25, 2010 06:44 PM
