V40 T4 nonstart intermitant
Old Sep 15, 2005 | 06:33 PM
barge's Avatar
Default V40 T4 nonstart intermitant
i have had a problem a few times now, car starts fine drive for approx 10-15 mins switch off car, go off and do what ever not necessaryly locking car , then return to the car and it wont start. All ign lights come on as normal transponder being read ok but car not cranking, have tried removing column shroud and having a bit of a poke around but nothing really to be seen, it always seems to happen when i have no tools on me to check voltages etc.. any ideas ???
Old Sep 15, 2005 | 09:59 PM
Default RE: V40 T4 nonstart intermitant
You will have to try to check for power at the starter when it happens.
Sometimes I will hook up a light that will come on everytime I crank the car.Then when it starts it will go off.
This way you will know if you have power to the starter or not.
Old Apr 8, 2007 | 02:18 AM
my_v40's Avatar
ORIGINAL: barge
barge, have you ever figured out the problem? seems like I am having the same issue. the battery is fine, but the car won't crank at all.
Old Apr 18, 2007 | 12:40 PM
MSchett2's Avatar
I had this same problem. The dealer finally figured out it was the crank sensor. It was not shielded properly. This was causing an intermittent problem.
katzpaw999
Jul 16, 2009 08:27 PM
katzpaw999
Jul 14, 2009 08:08 PM
abyjake740wg
Dec 9, 2008 01:10 PM
Beardog
Sep 7, 2007 08:21 AM
gtsteve
Aug 4, 2005 12:38 AM
