Rear wiper stopped working
Old Feb 4, 2009 | 03:25 PM
sjonnie's Avatar
Default Rear wiper stopped working
I checked the fuse, that seemed to be fine, but replaced it anyway, still nothing. What's the most likely scenario, broken motor? What's the best way to approach fault finding with this?
Old Feb 4, 2009 | 05:54 PM
b5254t's Avatar
most likely bad wiper motor, thats usually what it is.
Old Feb 10, 2009 | 05:18 PM
sjonnie's Avatar
Okay, well, I haven't looked into this yet but get this, I start the car in the parking lot outside the local store the other day, it was raining so I noticed, as I started the car up, the rear wiper did one swipe, then nothing. Switch won't make it come on, does that sound like a faulty switch or could there still be a fault with the electronics in the motor?
Old Mar 3, 2009 | 02:31 PM
sjonnie's Avatar
I wish all repairs were this easy. I just did nothing for a few months, now it's working again??
Old Mar 12, 2009 | 05:27 AM
R-P's Avatar
R-P
Hi Sjonnie,
I'm battling a problem with my rear wiper (V70 '04) and have found many postings about the wiring being faulty (runs through the left hinge).
My wiring was excellent, so I continued to search and have so far found that the gears and arm of the wiper have too much friction.
I have yet to find a solution, but if your wiper fails again, try to listen if you hear a slight clicking noise coming from inside the wiper-assembly. Sounds very much like a relay switching.
If you do hear this: it's a current limiting sensor build in by Volvo to prevent the motor (and/or fuse) from burning. It heats up due to too much current being passed and it switches off. When it cools down, it will give it another try, but will switch off again, etc.
I will continue to post any progress I make onto all Volvo forums (3 so far) I find, as there have been many people who have this problem, but the solution is not often included...
Old Nov 18, 2009 | 08:26 AM
R-P's Avatar
R-P
My issue was likely the bearings on the motor-axle.
Here's a full write-up of the solution.
DaveDog2010
May 17, 2021 09:00 AM
kydustinj
Aug 20, 2014 10:00 AM
kydustinj
Aug 14, 2014 11:00 AM
emacsp
Feb 24, 2014 05:02 PM
Marcin Olczak
Sep 4, 2013 12:56 PM
