service light comes on when i start the car
Old Mar 2, 2009 | 11:04 PM
STREETFIGHTER50's Avatar
Default service light comes on when i start the car
98 s70
service light is on when i start the car. turns off after a little while driving it. is this a reminder of some sort? how can i reset?
Old Mar 3, 2009 | 06:49 AM
Somthngfrce's Avatar
Yes, it is a Service Reminder. It comes on every so many miles. I can't remember what THE interval TECH told me but I wanna say every 5k? I think pre-97 850 vehicles, you can res-set the light manually. 97 850's and s70's and on you have to have a scanner do it. Mine came on and Tech took care of it for me as he has a scanner. You can go to a dealer and they should be able to reset it unless you can deal with the light. I couldn't, drove me nuts to look at it. I want to say IPD also sells a service light reset flasher, but its like $120.
Old Mar 3, 2009 | 07:26 AM
BlazeS70's Avatar
You could try disconnecting the negative battery cable for 30 seconds. Be sure you have the radio code before you try it though or else your radio won't work.
Old Mar 6, 2009 | 08:36 PM
vmarc15's Avatar
Default service light reset
I had the same problem i found out that some 1998 and up you can turn the key to make the lights come on holding the mile reset the light will flash 2 times then your done.good luck!
Old Mar 6, 2009 | 11:46 PM
so hold the trip/reset button down while turning the key to the on position?
Old Mar 7, 2009 | 10:59 AM
BlazeS70's Avatar
the warning lights on the dash or the headlights?
Old Mar 7, 2009 | 06:30 PM
vmarc15's Avatar
yes don't start the car hold the mile reset in then turn key till lights come on the service light will blink 2 times then your done on 1998 and up good luck!
Old May 9, 2009 | 06:13 PM
this did not work for my '98, S70. How long do I need to hold reset button in before I turn the car on?
Old May 9, 2009 | 09:32 PM
Johnny Mullet's Avatar
Up to 12 seconds actually.
Old May 9, 2009 | 11:08 PM
Default Service Light Will Not Reset on the '98's
Well, I could hold it for over a minute and it simply does not work. I also fired up my OBD-II scanner and it would not reset the light either. I read another post that stated that the trip reset does not work on the '98 models.
To reset the light on the '98 models you have to get the special tool or have a service tech do it. I guess it will stay on.
Old May 10, 2009 | 08:01 AM
Volvo4Life70's Avatar
I have a 98 s70, and according to mitchell on demand you need a scanner(thank god I have one) the dash reset only works for 99 & up sorry
Old May 10, 2009 | 03:01 PM
By scanner I guess you mean OBD-II code reader. If so, I'd like instructions on how to make it clear the Service Reminder light because I could not figure it out.
Old May 10, 2009 | 11:25 PM
BlazeS70's Avatar
I went to Precision to have a smoke test done and afterwards, the guy said he'd reset and clear the codes...but he couldn't turn the Service light off. You need to go to a Volvo dealership or someplace with a Volvo-specific tool to turn the Service light off.
Old May 12, 2009 | 12:12 PM
sbwilley's Avatar
Default Service Lamp Reset Procedure
The dash reset procedure only works if the light does not come on while the engine is running. The procedure is:
1. Press and hold Trip Odometer reset button
2. Turn ignition key to run position KPII(not the start position)
3. Wait 30 seconds or until service light begins blinking
4. Release Trip Odometer button
5. Turn ignition to off position
Old Sep 21, 2009 | 05:32 AM
smugbug's Avatar
Talking hehe
Mine comes on everytime but goes after about 5 mins.
Call me mad, but I quite like it. It acts as an indicator for me not to drive too hard,
Not sure how this applies these days but as a young man I was always told not to thrash a car from cold.
i.e. gives me five minutes to warm the engine up before I start releasing the 200bhp rollercoaster ride.
victory
Apr 3, 2010 05:59 AM
VR6Slvr
Jan 25, 2009 10:29 PM
ramona
Dec 11, 2007 04:19 PM
newfsowner
Feb 11, 2007 11:48 AM
