Air Conditioner
Old May 8, 2009 | 01:19 PM
mshkol's Avatar
Default Air Conditioner
I just recently purchased a 1999 Volvo S70 AWD with 136,000 miles. When I turn the vehicle on there are amber lights that flash on the air conditioner control ( I believe it may the air button and the recirculation button ). The AC blows cold air and the automatic climate control works.
What could this be? Is this just a sign that the AC will need to be recharged? Do all the models do this for a few seconds after they start?
Any incite would be great.
Old May 8, 2009 | 10:47 PM
The lights flashing means there is codes stored in the A/C computer.
Could be many things.
Old May 9, 2009 | 12:17 PM
elcs70's Avatar
mine flash for like 5 seconds after i turn the car on, then work fine, so its not really a problem imo
Old May 12, 2009 | 12:16 PM
sbwilley's Avatar
Default ECC Fault
Mine flash and then the A/C won't work. The manual says it's an ECC fault. How do I clear the code? It's a 2000 S70. Thanks.
Old May 12, 2009 | 08:25 PM
You need to have the codes pulled to see what they are and what is wrong.
Old May 13, 2009 | 10:43 AM
sbwilley's Avatar
Default Must A/C Codes Be Read by the Dealer?
I use the ODBII code reader at Kragen, and it said there are no codes stored in the system. It seems to only see engine codes. Is it possble for me to pull the codes myself, or do I have to see a dealer?
Old May 13, 2009 | 08:56 PM
You need to find someone that can read the climate codes.
HarryO
Jul 15, 2023 03:58 PM
gianni
2001-2013 model year XC70
Sep 18, 2013 03:33 PM
austeve
Jul 29, 2008 09:08 PM
Carbuff
Jul 26, 2005 01:14 AM
Carbuff
Feb 22, 2005 12:36 AM
