AC fan stops when you accelerate
Old May 15, 2009 | 01:08 PM
mgreen2's Avatar
Default AC fan stops when you accelerate
Why would the AC fan stop blowing when you accelerate? If I push down on the accelerator to get up speed quickly the AC stops blowing. This just started.
I also just noticed a high pitched wine noise when the recirculate option is engaged and it seems like air is coming in even if it is engaged. It would normally not have air coming in the vent if the AC was off and recirculate air button was pushed in, but now have air coming in all the time with the AC off.
Old May 15, 2009 | 07:19 PM
One of the vacuum diaphrams are bad. It might only be the recirc one or another one as well.
Old May 16, 2009 | 08:05 AM
mgreen2's Avatar
Is this something I could replace on my own? Complicated job? Any good refrence or instructions on how to do it? Thanks for the quick response.
Old May 16, 2009 | 08:25 AM
It is a pain but you can do it.
What alot of people do is screw the door so it is always open and plug the hose to stop the leaks. If one of the other ones are bad then I would leave it to someone else to fix as it is like a 7 hour job.
I do not have any diagrams handy. But remove the lower dash panel on the passenger side. Then by the firewall on your right side you will see a black cover that you will remove. The door and diaphram is there you should see it.
If you check with the car running and recirc on you should hear it leaking.
Old Jun 3, 2009 | 12:33 PM
mgreen2's Avatar
Default vacuum
How do you remove the old vacuum valve? Does it just snap in/out?
Old Jun 3, 2009 | 07:08 PM
Do you mean the diaphram?
If so you need to unscrew the screws in the vents and it is a major pain to replace. That's why most people just screw it shut and plug the vacuum line.
Old Jun 7, 2009 | 02:16 PM
mgreen2's Avatar
Default where is the valve?
I am pretty sure the recirculate one is the one that is bad bit I can't find a black cover.
I can see one of the vacuum valves but not sure it is the recirculate one. It seems to control the lower vents. If i close it the AC air comes out of it.
Photos are here.
Is this the recirculate control?
http://www.filesavr.com/dscn3477
If not, where is the black cover?
Right side, under dash on the passenger side.
http://www.filesavr.com/dscn3478
Next to middle console.
http://www.filesavr.com/dscn3479
Attached Thumbnails AC fan stops when you accelerate-dscn3477.jpg   AC fan stops when you accelerate-dscn3478.jpg   AC fan stops when you accelerate-dscn3479.jpg
Old Jun 7, 2009 | 03:10 PM
The first pic is the recirc bellows.
Old Jun 7, 2009 | 03:18 PM
mgreen2's Avatar
So if that door is push up is it in recirculate mode?
Old Jun 7, 2009 | 03:21 PM
Yes the door up is recirc mode. Door down fresh air mode.
Old Jun 7, 2009 | 04:12 PM
mgreen2's Avatar
Can't get the old one out!! It has 2 nuts that look to be holding it in but I can't get them loose. May have to save this job for another day.
Old Jun 7, 2009 | 04:29 PM
It is a main pain in the A**. You have to also remove nuts from under the hood and pull the box away from the firewall as well to be able to get it out.
nicolas414
Oct 9, 2024 12:53 PM
ingydrummer
Feb 28, 2020 03:33 PM
amebb
1998-2000 model year V70
Oct 20, 2012 05:51 AM
jaymac
Jun 20, 2006 11:51 PM
harveydave
Aug 16, 2005 12:36 AM
